Wacky Idea For A Mosrite Bass Project
rcblair
Re: Wacky Idea For A Mosrite Bass Project
Postby rcblair » Wed Jul 25, 2012 1:07 pm
I'm running 3 volume controls and 2 concentric knobs for the mid and bass/treble controls on the BQC circuit. The nice thing about EMG pickups is you don't have to ground the bridge.
Rick B.
rcblair
Postby rcblair » Sat Aug 11, 2012 5:28 pm
Getting into the more detailed finishing stages. The routing is done on the body and I'm doing finish sanding before priming. Started putting finish on the neck. The birdseye looks really nice under varnish.
Rick B.
Postby MWaldorf » Sat Aug 11, 2012 11:30 pm
Wow - looking great. It's so wrong, it's 'rite! :)
rcblair
Postby rcblair » Sun Aug 12, 2012 5:58 am
MWaldorf wrote:Wow - looking great. It's so wrong, it's 'rite! :)
Hmmm. I've been wondering what I should name this bass. Wrongrite might not be bad :D
Rick B.
rcblair
Postby rcblair » Sat Sep 01, 2012 7:50 am
One major step almost completed. I used one of the Duplicolor paint shop colors on the body. It's much darker in artificial light but I wanted to try to get some pics of the metallic in the paint. I'll give it a week to cure and then wet sand and polish.
Rick B.
Postby KRamone27 » Sun Sep 09, 2012 2:20 pm
So rewarding for me to see a body I built being transformed into something awesome. Great job Rick. Witch duplicolor paint shop did you use? Was it rattle can or the 1/2 gallon cans?
ludobag
Postby ludobag » Sun Sep 09, 2012 2:49 pm
nice color ;)
rcblair
Postby rcblair » Sun Sep 09, 2012 3:32 pm
KRamone27 wrote:So rewarding for me to see a body I built being transformed into something awesome. Great job Rick. Witch duplicolor paint shop did you use? Was it rattle can or the 1/2 gallon cans?
I used the quart cans that you can buy at Advance Auto. I remembered seeing a blue that looked similar to the original blue. The color is darker inside and there is almost a little purple in the color. I have a compressor so I bought a paint gun set at Lowe's and did the spraying in my garage. I was afraid the metallic would come out streaky due to my lack of experience with the new gun, but the instructions say to spray a mist coat ~14" away while the last coat is wet to lay down more metallic particles. It came out nice and even. I used 4 coats of color and 6 coats of clear - that used up ~3/4 of each can. I used the Duplicolor primer as a base coat and sealer.
The top and back of the body are finished sanding. I should have the sides an curves done in a couple of days and I'll post more pics of the body in artificial light.
Rick B.
Postby olrocknroller » Sun Sep 09, 2012 4:18 pm
Nice job! That color will really pop with the birdseye maple fretboard!
rcblair
Postby rcblair » Tue Oct 16, 2012 12:52 pm
Almost finished. My son is cutting some aluminum for the bridge cover and after that is finished I can make the pickguard. I already have the white pearloid blank. Going to try it out with the band this week.
Rick B.
Users browsing this forum: No registered users and 522 guests
