6G6-B Bassman clone project
Re: 6G6-B clone project Question
Postby dubtrub » Tue Apr 24, 2012 12:15 pm
Got some sheet metal fabrication done today. First I made the brass plate and then the cap can cover.
I know most of this stuff is pretty boring but the stuff you don't see is the most critical. It won't start looking like an amp until I get down to the woodwork.
Re: 6G6-B Bassman clone project
Postby Mr. Bill » Tue Apr 24, 2012 2:32 pm
Dub, one of the features of the cover was to act as a hold down to keep the caps from vibrating until one of their leads would break from fatigue. They would use a thick rubber weatherstrip glued into the inside of the cover that would press down onto the caps when the cover was screwed down to the chassis.
I don't know if your cover was designed to work this way or not, but you could use some foam pads to act as vibration limiters.
Postby MWaldorf » Tue Apr 24, 2012 11:08 pm
Looks great Danny. How'd you bend the metal of the cap cover? The edges look really crisp. Do you have a metal brake?
Postby dubtrub » Sat Apr 28, 2012 11:25 pm
Mel, I used my five inch vice to make all the bends.
I'm getting out of order on how I was going to assemble this but while waiting on parts to arrive I have to work on what I can. Plus they still haven't got the faceplate made. It was suppose to be ready yesterday but they haven't sent me the final proof to approve. I guess since I had to pay for it in advance they are in no hurry.
Postby MWaldorf » Sun Apr 29, 2012 12:22 pm
Looking great Danny!
Postby dubtrub » Sun Apr 29, 2012 4:15 pm
Thanks, Mel!
I'm at a complete standstill now as the switches were not shipped with the original order even though the invoice shows they were. I sent them an email and hopefully they'll be sent ASAP.
Postby JimPage » Sun Apr 29, 2012 4:25 pm
Danny, that is stunning work; astonishingly clean and well laid out. The amp is going to be wonderful and worth all the effort you've put into it!
ludobag
Postby ludobag » Mon Apr 30, 2012 9:00 am
as always fabullous :lol:
i am again a little scare about hight tension but i think more and more to made my own reverb cause the ri cost too much in europe near 1000 dollars
and when you see what is inside :shock: the price is really hight ,i have already made some floor effect but an amp like you made is at this time too much complicated :o
if it work when i plug it at the first time ok but if i have to repair :?
your amp is like the better custom shop relly clean and well wired ;)
Postby Mr. Bill » Mon Apr 30, 2012 9:18 am
Great work there Dub. I can't wait to see the front panel.
Question for you, does the power transformer's 6 volt winding have a center tap? I see the red/yellow wire which I assume is the high voltage ct, but I didn't see a green/yellow.
Postby dubtrub » Mon Apr 30, 2012 9:36 am
Mr. Bill wrote:Question for you, does the power transformer's 6 volt winding have a center tap? I see the red/yellow wire which I assume is the high voltage ct, but I didn't see a green/yellow.
No it does not have the green yellow center tap. Do you see a problem there? Should that red yellow ct be lifted and capped with a wire nut?
It's this transformer here.
http://www.tubesandmore.com/scripts/fox ... m=P-T290EX
Users browsing this forum: No registered users and 793 guests
