style" mosrite of burgundya"
Postby Veenture » Thu Aug 02, 2012 9:36 am
Wow, you work fast! Looking good :)
Postby MWaldorf » Thu Aug 02, 2012 9:45 am
Wow, Ludo, that's impressive!
ludobag
Postby ludobag » Thu Aug 02, 2012 9:54 am
thanks but not as fast as i would (if i can do at work it will be more easy :roll: )
then with 180 sanding
i think my quarter round are a bit too much :| but i am not redo one :oops:
after with going highter in grit i think lot of mistake (bump ,hole ,scratch ect) will be show but then it will be for finishing
i have 2 other part to do :lol:
ludobag
Postby ludobag » Fri Aug 03, 2012 1:50 am
rocking part
the way to do it
first the 2 holes for axis on the block written
after sawing all not needed :o rest not much
i have to put every thing square now and after rest the hole for string and arm
and after all the shape of bean (is easyer to catch something square)
ludobag
Postby ludobag » Fri Aug 03, 2012 11:28 am
a little more ;)
ludobag
Postby ludobag » Sat Aug 04, 2012 3:41 am
it advance well again 3mm too hight on the curved part and the bean shape eed to be worked too
:o i have think i have made a mistake cause my arm is offset (i have 2 mesurement for the offset of the arm ,one 5 mm (this one i have use) and an other 7 mm (maybe i must have use the middle 6mm ?
but when i have look at original there is also this offset :ugeek:
then when i look at pics closer it is not easy to see cause chrome and curve don't help
but now i have seen my arm miss a quarter round under,the shape of the rocking need to be work too (i wait the final thickness cause 4 mm is easyer too shape than 8 mm :lol: )
Mosrite user 's do you think my arm is so much offset ?
in the bad case i could fill the hole and redrill it will be not visible cause under the arm
mikethemod1992
Postby mikethemod1992 » Sun Aug 05, 2012 11:43 am
great work :)
ludobag
Postby ludobag » Sun Aug 05, 2012 12:50 pm
thanks ;)
ludobag wrote:2 thing i need also (not for the trem i have lot even much more :lol: )
what is the Larger of the headstock i have 7 cm at the larger point ? it is good ?
and what is the size of the pups, the ring where the pups is attach ? (lenght x larger and radius corner ) need it to make my guard template ,please ,i wait my M3 pups but if i can have the mesurement before i could do some thing without waiting
:?: nonody knows ?
don't be afraid to answer :lol: thanks by advance ;)
after this advertising page
now the trem continu :twisted:
it works need to be more beautiful cause it is really roots :lol:
a mistake i have some hole deeper :evil:
but with the bridge only one appears really :ugeek:
and aluminium is nice but wood is better and more over easyer to work too :lol:
i will finish the shape soon but i don't know with what need to think about that something like dremel or surely electric cause i fed up with file :roll:
ludobag
Postby ludobag » Tue Aug 07, 2012 2:45 pm
rest some work but it is less square ;)
Postby MWaldorf » Tue Aug 07, 2012 5:57 pm
Wow! :shock: :shock: :shock:
Users browsing this forum: No registered users and 529 guests
