Gibson Melody Maker To LP JR Conversion
Re: Gibson Melody Maker To LP JR Conversion
Postby oipunkguy » Tue Jan 15, 2013 10:13 pm
next step was to trim down the thickness of the body down to 1 and 3/4 inches. which isn't the easiest thing to do without a thickness planner. even if I had one, it would be difficult to use with the neck already attached to the guitar. so in order to do this I used another piece of wood cut to 1 and 3/4's and used it as a guide and used my router to remove the excess wood.
Postby oipunkguy » Tue Jan 15, 2013 10:14 pm
Postby oipunkguy » Tue Jan 15, 2013 10:16 pm
here's what she looked like after the routing. not pretty, but that's what sanders are for :lol:
Postby oipunkguy » Tue Jan 15, 2013 10:17 pm
in no time it began to clean up nicely.
after sanding with the obital sander i switched over to the bench top belt sander. :)
Postby oipunkguy » Tue Jan 15, 2013 10:20 pm
drilling the output jack hole.
Postby oipunkguy » Tue Jan 15, 2013 10:27 pm
sawdust anyone?
Postby oipunkguy » Tue Jan 15, 2013 10:32 pm
began routing the control cavity.
Postby oipunkguy » Tue Jan 15, 2013 10:35 pm
Postby oipunkguy » Tue Jan 15, 2013 10:38 pm
rough cut the cavity for the back plates
Postby oipunkguy » Tue Jan 15, 2013 10:43 pm
after all the major routing was complete I sprayed down the bown with water to raise the grain.
so the next day when it was dry I could sand it and get out a lot of sanding marks cause from using the heavier duty sanders.
Users browsing this forum: No registered users and 386 guests
