I've never built a bridge before...
drbassman
Re: I've never built a bridge before...
Postby drbassman » Tue Nov 18, 2008 6:21 am
Almost finished. I used ebony and Danny's measurements...........
gogoriotgirl76
Postby gogoriotgirl76 » Tue Nov 18, 2008 2:47 pm
KRamone27 wrote:Well today I got it looking like a real bridge but I still got some shaping and string notching to do.
and that took him forever...but I think it looks really good!!!
Postby KRamone27 » Tue Nov 18, 2008 6:42 pm
That tailpiece looks like it turned out pretty good. How thick of angle aluminum did you use? Kevin
drbassman
Postby drbassman » Tue Nov 18, 2008 8:06 pm
KRamone27 wrote:That tailpiece looks like it turned out pretty good. How thick of angle aluminum did you use? Kevin
I found 1/8" X 3/4" at Home Depot. just what I needed.
Postby KRamone27 » Sat Nov 22, 2008 5:37 pm
Well I got the bridge that I bought off of ebay and there's a lot of differences between what I built and the actual Mosrite bridge so I guess it's back to the drawing board. I'm trying to make an as accurate of a Mosrite bridge as I can for my clone.
Postby KRamone27 » Sat Nov 22, 2008 5:41 pm
In case I didn't show the bridge I got here it is.
Postby dubtrub » Sat Nov 22, 2008 5:43 pm
It's always better when you have something to examine. If I recall correctly, that bridge was from Kevin Zamm and he advertised it as being a wider string spacing. So be aware of what you put it on. ;)
Postby KRamone27 » Sat Nov 22, 2008 6:25 pm
actually the base plate is aluminum and the adjustment screws were really tight against the base plate so I fixed that right away but as far as the string spread it's spot on at 2" but the rollers are seized so I thought about doing what you did with those tuners and soak em in mineral spirits to try to free them up. But it's in overall great shape.
cal0101
Postby cal0101 » Fri Jun 27, 2014 9:00 am
What size channel aluminum did you use I am thinking about making one for my mdf bodied replica I built
Thanks,
Caleb
My 1960 Euro spec VW beetle ragtop
cal0101
Postby cal0101 » Fri Jun 27, 2014 9:01 am
Thanks,
Caleb
Users browsing this forum: No registered users and 756 guests
