Postby Sarah93003 » Thu Jun 02, 2011 11:19 pm
olrocknroller wrote:Now there's some cool photo work! You must have one of those Dick Tracy miniature cameras...oh wait, they used film, and took a couple weeks to develop... Come to think of it, you may not even remember Dick Tracy! So...how did you do it?
iPhone and a flashlight :mrgreen:
Postby Sarah93003 » Fri Jun 03, 2011 1:16 pm
While having my morning coffee I decided to give the MOP a whirl to see what that is like to work with.
First I used some acrylic plastic to make a "template" of the "S" curve that I want. This is only for the first block as each block gets smaller and smaller in height so the "S" curve will change for each block. My goal was to make a template that will allow me to be consistant with the degree of the curves.
Using the template, I used a fine tip Sharpie to make the S curve in the center of the block.
The trusty jewelers saw cut through the MOP just fine, but it is definately harder and therefore a little more time consuming that the turqoise.
Once the cut was made, I now have the left and right sides of my inlay block.
I used my baby files to dress up the edges and make sure my "seams" are going to be nice and smooth.
Satisfied with my two sides, I then cut out the center from the turquoise. This is the rough cut that will be filed and fitted between the two pieces of MOP. I'll do that tonight as I ran out of time this morning and had to get to work!
More to come!
Postby MWaldorf » Fri Jun 03, 2011 2:23 pm
Looking good Sarah!
Postby Veenture » Sat Jun 04, 2011 8:55 am
Sarah93003 wrote:I decided to give the MOP a whirl
So you're a poet too... :mrgreen:
A fascinating tour of unusual surroundings -the insides of one sound chamber! Sarah, if you hadn't told us, I daresay we'd never 've known! Thanks ;)
Postby Sarah93003 » Sat Jun 04, 2011 10:19 am
You are so funny! As for the sound chamber tour, my pleasure. It helps me to understand the guitar a little better if I have a peek at how it was constructed and what is in there. I discovered a couple of metal objects that I will need to remove to add my extra sound holes.
Postby Sarah93003 » Sat Jun 04, 2011 10:23 am
Today's update.
This morning I cut the remaining pieces for the first fret marker. It is comprised of three pieces in total. They are about 95% fitted and require some light sanding to get the pieces the same thickness and remove any minor speed bumps. I laid the three pieces onto transparent tape so that I can handle it and photograph it.
I put the marker on the old fretboard of the guitar. This is the damaged fretboard but it is cut to the proper width and I have yet to cut the new one to lenght and width. So, ignore the old thumbnail marker and it should give you an idea of what I'm going for. One image is with a flash and one image is in natural light.
With a flash.
Natural Light.
I need to get some other work done before I start on marker number two.
Postby olrocknroller » Sat Jun 04, 2011 3:47 pm
:shock: You've been taking notes from Oigun! That is going to look absolutely fantastic when it's done. :mrgreen:
Postby olrocknroller » Sat Jun 04, 2011 3:55 pm
Just looked at your photos again, and remembered your earlier concerns about the extra openings weakening the top...that support under the bridge should make those concerns fade away...
Postby Sarah93003 » Mon Jun 06, 2011 3:34 pm
I've made the second fret marker and you can get an idea how the fretboard will look as I continute down the line.
Postby Sarah93003 » Tue Jun 07, 2011 9:53 am
Well, here it is with the logo pretty much in place. Not perfectly located but close.
Users browsing this forum: No registered users and 509 guests
