Bluesbender serial numbers (edit: old serial number list)
- moaimen
Re: Bluesbender serial numbers
Wow! I've been away from the forum here for ten years now and today I got back on and am blown away by you guys! I started this thread in 2009 and it's taken a life of it's own, unbeknownst to me. Great job, I've got some catching up to do for sure, I guess I'm not the only one after all, into the Mosrite saga and I still have NO 170. Used to have NO 045 and always wondered where it wound up...
moaimen wrote:Wow! I've been away from the forum here for ten years now and today I got back on and am blown away by you guys! I started this thread in 2009 and it's taken a life of it's own, unbeknownst to me. Great job, I've got some catching up to do for sure, I guess I'm not the only one after all, into the Mosrite saga and I still have NO 170. Used to have NO 045 and always wondered where it wound up...
Welcome back!
- 101Volts
Welcome back. It's suprising what information is already available online about these guitars, outside sales ads that show up at maybe 1 - 3 per year. Some of the info was found by doing web searches and facebook searches. It took a while, but there really aren't many Blues Benders around in the first place; maybe 200 - 300 (though, that's a speculated number range.)
NO 077 and NO 177 both showed up at about the same time, from the same seller. Sometimes, these guitars just show up in pairs or groups. I've seen the same thing for the 350 models, once, in 2010 or 2011.
Update to the list for this reply:
moaimen, since you've mentioned that you owned 45 and 170, I've added notes to them. Also, what finish did NO 045 have, and what finish does NO 170 have?
(Edit on 29 April 2024: an earlier version of the list was here, but I snipped it to condense the thread.)
- 101Volts
Re: Mosrite 500 Blues Bender model Serial Numbers List (1970s, Les Paul-ish Shape.)
Recent Updates:
5 July, 2023:
I've considered removing the colored text from some instruments, because maybe it's hard for colorblind people to see them? I'm not sure if I'll remove the text, though.
I've also found what seems to be NO 065 (Black) for sale, but I'm not sure. EDIT: It's NO 050, actually, according to the seller.
https://www.facebook.com/groups/3294258 ... 223967899/
https://centaurguitar.com/products/mosr ... 9074&_ss=r
29 July, 2023:
No 056 (Black) Added. Shows some paint wear through, right where the strumming arm rests.
19 August, 2023:
Unknown # Red Burst Model (Without M Knobs, so it's probably in the NO 170 - NO 205 range) found on Facebook, posted 16 August at Ben Owens Music, Inc.
https://www.facebook.com/benowensmusici ... GAgQwdrhDl
7 February, 2024:
NO 061 (Black) Added. Missing truss rod cover.
8 February, 2024:
Mystery Number added - Red.
I also re-organized the list to put the Known #s on top, and everything else beneath it.
22 February, 2024:
Took 5 of my own redundant replies from 2019 - 2020, saved them to text files, and deleted them from this topic (in effort to clean up this thread and make it easier to navigate.) Reply Count down to 89, from 94.
3 April, 2024:
NO 160 updated. It's Black, and it's owned by Dr. Michael Marks.
http://web.archive.org/web/201008270004 ... 35039.html
28 April, 2024:
Started condensing this thread from my own excessive replies.
29 April, 2024:
Removed more posts. The topic was at 10 or 11 pages, now it's down to 5.
21 September, 2024:
NO 068 sold another 2 times on Reverb in Late 2024 / Early 2024.
28 September, 2024:
Blank Burgundy was posted on Reddit about 12 days ago, and then I found the listing for it.
Reddit:
https://www.reddit.com/r/Mosrite/commen ... with_this/
Carter's Vintage listing:
https://cartervintage.com/shop/mosrite- ... RjjINZb8Cy
24 July, 2025:
NO 084 added. Has a Moseley Tailpiece.
Model Trivia:
The Mosrite "500 Blues Bender" Model (though you could omit the "500" from the name, I'm just being most formal) is a Mosrite take on a Gibson Les Paul, with typical 1970s Mosrite appointments, save for the Humbucker Pickups and a Stop Tailpiece instead of a Vibrato Tailpiece. These also have a wider neck than 1960s models, but that's typical of 1970s Mosrites.
It seems that about 205 - 225 were originally manufactured in a rough range of 1971 - 1974, with a few others up to 1978. Serial Number Lists were lost in a factory fire in November 1983, we don't know when the numbers started or stopped.
Model Specifications:
Basswood Body
Bolt-On Maple Neck, Rosewood Fretboard, Binding on Neck
24.50" Scale Length (Typical of Mosrite Guitars)
Mosrite Humbucker Pickups (Mostly a 1970s thing for Mosrite)
Grover Tuners (typically, at least)
Zero Fret
Phase Switch
Knobs are usually Mosrite "M" Knobs, but late models (roughly NO 180 and beyond) may have off-brand knobs. Late models after 190 also tend to have a big pad on the back, akin to the last of the "Acoustic" brand's Black Widow Models that Mosrite were assigned to manufacture.
If you'd like to contribute a Blues Bender to the list:
If anyone would like to contribute info of their guitar, please do. We will need to know these key points:
1: Body Finish.
2: Neck and Headstock Finish.
3: Serial Number (on the fretboard, between some of the highest frets, near the neck pickup.)
4: If you have the original pickups and are willing to remove them to check, then please check their bottoms for dates.
5: What kind of knobs does it have? Many have Mosrite "M" Knobs, others (mostly after B170) do not.
6: Does it have a big pad on the back, akin to the Mosrite built Acoustic Black Widow models? I've only seen this on later models, after B180, but I need to know.
If you can share photos of the guitar, that would be well appreciated in these efforts to preserve Mosrite history; I'll save the photos.
Or, if you just found one online somewhere that I missed, just share the link.
Serial Numbers List:
Known # Section: 48 Guitars
NO 001: Unknown Finish. Mentioned at Let's Talk Guild (Forum,) in July 2019: https://letstalkguild.com/ltg/index.php ... st-1848337
NO 003: Unknown Finish.
NO 015: Black, appears to be unmodified. Pics and page saved. Showed up for sale from Guitar Wishes in 2019, and they made a video about it. https://guitarwishes.com/product/mosrite-blues-bender/ and the YT video: https://www.youtube.com/watch?v=Sf88_jsz33k Later, showed up on Reverb on February 21, 2020 from "Weird/Unique Guitars." Reverb Ad: https://reverb.com/item/32577326-mosrit ... 1970-black UPDATE for May 16, 2021: Owned by Ryan Tucker, who's on the Mosrite Fan Page on Facebook.
NO 016: Black with Sunburst Headstock. Pics and page saved. Showed up on Reverb in November 2019 in a case and in very good if not excellent condition. This is the only model currently listed with a Sunburst Headstock, and it may be the only one. 1st Reverb Ad from Reverend Guitar Man in Marysville, WA: https://reverb.com/item/29460726-1971-m ... -500-black YT Video: https://www.youtube.com/watch?v=9iO_qqE77jA | 2nd Sales Ad from Southside Guitars in Brooklyn, NY on February 2, 2021: https://reverb.com/item/38647011-mosrit ... 70-s-black
NO 019: Black. Was owned by Doug Niemczura in the 1990s. The original Phase Switch broke, so he replaced it with a metal one. Mentioned in comments at this FaceBook page: https://www.facebook.com/groups/1048518 ... 250370631/
NO 020: Unknown. Mentioned in a sales ad from a newspaper classified, if I recall correctly. No photos, this is all I know about it.
NO 028: Black. Pic saved. Described as "Dark Burgundy," but it just appears to be the standard Black for these models.
Source: http://www.ne.jp/asahi/mochizuki/kiyosh ... rlist.html
NO 031: Black. Pics saved. Owned by Tim Brennan (of Tym Guitars in Australia.) https://tymguitars.com.au/blogs/blog/14 ... O-ptJ6SsAo
NO 032: Black. Refretted and modified. Type of knobs unknown. Seen on eBay in October 2010. viewtopic.php?f=27&t=3676 | Update, 21 July 2021: More pics of what's probably this guitar were sent to me the previous month, and saved. It has Gibson type Humbuckers on it, without the covers.
NO 039: Unknown Finish.
NO 040: Refinished in some sort of Pink / Yellow. Pic saved. Belongs to Michael Flores.
NO 041: Unknown Finish.
NO 045: Formerly owned by forum member "moaimen." viewtopic.php?p=71553#p71553
NO 049: Black. Has heavy weather checking.
NO 050 - Black. Was put up for sale in late April 2023, and I missed it for months. --- https://www.facebook.com/groups/3294258 ... 223967899/ ---https://centaurguitar.com/products/mosrite-blues-bender-500-w-ohsc-vintage-1970s?_pos=1&_sid=5608b9074&_ss=r
N)
056: Black. Has some paint wear through where the strumming arm rests. https://reverb.com/item/71821331-mosrit ... r-500-1971
NO 061: Black. Missing Truss Rod Cover.
NO 068: Black. Missing original pups & knobs. Seller said it's a 1972 model. Update, April 14 2020: For sale from "Britt's Gear Depot" in Texas. The pickups have been replaced with Hallmark Humbuckers, a good replacement. Still doesn't have original knobs. Also has a worn "Lew's Music Center" sticker on the back of the headstock. Comes with a case, maybe the case is original? Reverb Link: https://reverb.com/item/33259555-mosrit ... k-burgundy Update, May 29 2020: Now owned by Forum member Steelaire17. viewtopic.php?f=4&t=7990 Update, 21 Sept 2024: This one was sold two more times on Reverb. Ad 1: https://reverb.com/item/77447679-mosrit ... _sold=true --- Ad 2: https://reverb.com/item/77794168-mosrit ... _sold=true
NO 071: Black. Pic and page saved.
Source: http://home.insightbb.com/~marksma/wsb/ ... ip-35.html
NO 073: Black. Original pickups removed and replaced with Gibson-type pups. Knobs were also replaced with Gibson-type. Found on Facebook: https://www.facebook.com/photo/?fbid=10 ... foAFvO6NMM
NO 077: Refinished in a Metallic Pink (Originally Black.) Does not have M Knobs, they may have been replaced. Pics and page saved. Has TV Jones Pickups on it. Knobs aren't original. Body has binding on both sides, which is unusual, to say the least. I'm uncertain if the binding is original or not. Sold by "RETROVERB MUSIC, INC." Listed in early April, 2020. https://reverb.com/item/33130313-mosrit ... 4Q3AJFzg1k --- Update, 26 November 2021: Guitar re-surfaced on eBay from seller "tuneyoursound" in Durham, North Carolina.
NO 081: Black. Owned by Jim Diamond.
NO 083: Red.
NO 084: It may be Red or maybe it's still "Black" (Dark Plum.) Also has a Moseley Vibrato Tailpiece.
NO 087: Red (not sure if it was refinished or not.) Had a neck repair that wasn't touched up. Seen on eBay in October 2010. viewtopic.php?f=27&t=3663
NO 101: Brown. Owned by forum member chartbreaker who bought it (apparently) new in 75 - 76. Played hard, well enjoyed, and has a knife mark between pickups.
NO 107: Brown. Does not have M Knobs, though I'm not yet sure if they're original or not. Does not have its original bridge, it has Tune O Matic type bridge, and beneath that, the base for an acoustic. This guitar surfaced at the Facebook page "Mosrite Guitar Fans," posted by Rosey Storey; it was her Father's guitar. Link: https://www.facebook.com/groups/3294258 ... 996838729/
NO 110: Black. Pic saved. Number is according to Photobucket pictures, which I couldn't download. Has a pink-ish ring around the pickup selector, and is missing one original knob. Also has an odd looking logo on the headstock. Found on Facebook, posted by Rozhan Bin Asaad in Kota Kinabalu.
NO 113: Brown. The second owner, Cary Zaborowski (who owned it since 1972) has it. Found on Facebook under the "Mosrite Guitars" Group in December 2020. Pic saved.
NO 119: Brown. Pics and page saved. Seems to have been parted out on eBay. Sources:
https://reverb.com/item/2852359-brown-c ... del-guitar
https://www.ebay.com/itm/Mosrite-1970-B ... SwuoxanXpS
NO 120: Brown. Bought by Pete Kenny in or around June 2023. Potentiometers date to October 1970. https://www.facebook.com/groups/mosrite ... 362948984/
NO 122: Stripped, and is Red in the control cavity with Black around the edges, so I'm not quite sure what to make of this one; was it Red or Black? Otherwise, this one's all original. Showed on 8 - October - 2021, on Facebook Marketplace. Pics saved. https://www.facebook.com/groups/3294258 ... 344197959/
NO 127: Brown. Pics and page saved. Showed up on Reverb on September 1st or 2nd 2019, from West Kentucky Music and Pawn (Location: Mayfield, KY.)
Source: https://reverb.com/item/26263169-mosrit ... 1970-brown
NO 133: Unknown Finish.
NO 135: Black. Pics saved. Seen for sale on eBay U.K. in May 2012. Once owned by Forum Member "ron," and I'm not sure if he still has it. viewtopic.php?p=54702#p54702
NO 140: White. Perhaps this was dorkrockrecords' guitar listed in the unknown exact numbers section?
NO 153 "Deluxe:" Black. Pic and page saved. Does not have M Knobs in the saved photo. "Made in 1969. It is black with a red tortoise shell pick guard. The scale is 1/8" shorter than the Gibson scale. After taking this picture, it has since been completely restored by my father, the master luthier Bill Gruggett, an original member of the Mosrite Guitars team. Original Mosrite parts were used from his personal stock, except for new high-quality PC-USA pickups, which I requested." Note: I think the "1/8 shorter than Gibson scale" note is wrong; it probably doesn't differ from the typical 1/4 shorter than Gibson scale.
NO 160: Black. Owned by Dr. Michael Marks. http://web.archive.org/web/201008270004 ... 35039.html
NO 162: Black. Does not have M Knobs, it has Radio Shack-type Knobs. Pic saved from Ne.jp. Was owned by Sumlin, and is currently owned by Mark Burletson. Update, June 15 2020: Better photos found and downloaded from the Gretsch Talk Forum. 1st Link: http://www.ne.jp/asahi/mochizuki/kiyosh ... rlist.html 2nd Link: https://www.gretsch-talk.com/threads/ng ... dd.193415/ Update, February 14 2021: Showed up for sale in the United Kingdom in July 2020, from "Markeebee" at the "TheFretBoard.co.uk" Forum. https://thefretboard.co.uk/discussion/1 ... d-mosrites
NO 170: Owned by forum member "moaimen." viewtopic.php?p=71553#p71553
NO 172: Sunburst.
NO 177: Black. Pics and page saved. Number's according to the seller. Appears to be stock. Finish has much checking, and a spot of paint's missing by the output jack. Seller is "RETROVERB MUSIC, INC." https://reverb.com/item/312458-mosrite- ... t-bXLAho0k
NO 180: Translucent Brown, or perhaps a variant of Natural? Does not have M Knobs, but the Radio Shack-type knobs may be original. Pics and page saved.
Source: https://reverb.com/item/3369670-mosrite-bluesbender
NO 190: Red Burst. Pic Saved. Does not have M Knobs, but the Radio Shack-type knobs may be original. I can't tell if it has a Black Widow-type Pad on the back, or not. This instrument was on eBay in 2010. Pic found here: https://www.popscreen.com/prod/MTI5MTU3 ... N0190-eBay
NO 195: Unknown Finish. Has a Black Widow-type Pad on the back.
NO 196: Black. Pic and 2010 eBay description saved. Does not have M Knobs. Signed by Nokie Edwards. I don't know if it has a Black Widow-type Pad, or not; there was only 1 photo of it in the listing.
NO 202: Black. Pics saved. Does not have M Knobs. Has a Black Widow-type Pad on the back. Was for sale on eBay in April 2011.
NO 203: Unknown Finish.
No # Stamped (or Number Missing) Section - 5 Guitars:
Blank: Black. Pic saved. Found for sale on Facebook on July 1, 2021, in England. Has a White Pickguard and Knobs that are not "M" Knobs, but otherwise appears original. Has the name of the original owner (who was a Korean War Veteran from Bakersfield, Cailfornia) on the inside of the back plate.
Blank : Black. Owned by forum member TimR. Pic saved.
Blank: Burgundy. Pics and page saved. One pic of it was posted by "Mississippi Ave" on Facebook in 2017. Pic says "BlackBookGuitars" at the bottom, and I found a Sold page for it at that site. https://www.blackbookguitars.com/produc ... c143&_ss=r --- Update, Sept 28 2024: Found more photos of it. Reddit:
https://www.reddit.com/r/Mosrite/commen ... with_this/ --- Carter's Vintage listing:
Blank - Natural Mosrite / E. F. Elliott Partsrite. Pics and Mosrite Forum Page saved. Brass Rail Deluxe Body and Tailpiece, Mosrite Sooner Neck, Mosrite Humbuckers, Unusual Pickguard, Black "M" Pad on the back. Once owned by Adam (Dorkrockrecords, AKA Expat Guitars.) This is one of the last Blues Benders to ever be built, and it was finalized in 1978. (I can't say "Finished," can I?) Link: viewtopic.php?f=11&t=1545&hilit=bluesbender&start=10
Blank : Red Burst, with Deluxe Electronics. Pics and page saved. Owned by Tim Brennan. Has a Bigsby, and 2 M knobs but not 4. This is either a rare Deluxe model, or it's modified, or it may even be the only one that was made with active electronics:
https://www.tymguitars.com.au/blogs/blo ... kpBMie_np0
Partial # Section - 2 Guitars:
NO 002, NO 002x, or NO 062: Black. Pics and pages saved. Found at HewittsGarageStudio, a small site. Photos were posted in 2009. Page is down. http://www.hewittsgaragestudio.com/gall ... ?g2_page=4 UPDATE: New page. A picture here makes it look like this one's NO 062. It also says the owner's name is Sean French. http://www.hewittsgaragestudio.com/Item ... nstruments
NO 03x/04x: White. Once owned by Adam (dorkrockrecords.)
Speculated # Section - 2 Guitars:
NO 132 or NO. 137 - Red Burst. Does NOT have M Knobs, but Black Plastic Knobs. Listed on eBay on 2 or 3 Jan 2022, from seller "westcoastsalez." Pics and page saved. I'm not sure I got this one's # right; the second digit is hard to tell in the only pic I have, & the last digit may have a misprint next to it, making it a misprint of NO 132 or NO 137. The guitar could be 117, 132, 137, or (seems to be less likely) 182, 187, 192, or 197. It does not have the "M" Pad on the back, so it seems to be Pre-190. Then again, Mosrite's inconsistent enough that an omission may not indicate a Pre-190 guitar.
Blank or NO x25: Red. Pics and page saved. Neck's stripped and neck pickup cavity routed so the bottom end could be closer to the bridge. The pics seem to show that there's no number, but I can vaguely make out a 25 in there, which may or may not be me imagining things. Available from Gonkulator on Reverb Late April 2018, sold later: https://reverb.com/item/11837350-mosrit ... er-project
Unknown # Section - 15 Guitars:
(One or more of these may or may not already be on the list, elsewhere, with a number.)
Moseley Instruments - 1 Guitar:
NO xxx: Has "Moseley by Semie Moseley" on Headstock, and is painted a bright Red. Has a Moseley Vibrato on it without the baseplate, and has a Black Widow type Pad on it, so it has to be a late model. It may be a partsrite, or maybe not. Pics and pages saved. Owned by, or formerly owned by Forum Member "stringbander." (that's "stringbander," not "stringbender.") Links: 1: viewtopic.php?f=4&t=6002 2: viewtopic.php?p=61399#p61399
Mosrite - 14 Guitars:
NO xxx: Brown. Pic and page saved. Found at Black Book Guitars. https://www.blackbookguitars.com/collec ... esbender-1
NO xxx: Black. Is missing the truss rod cover in these pics, and has a chunk of finish missing from the lower rear edge, where it would sit on your leg: https://www.gbase.com/gear/mosrite-blue ... 1973-black
NO xxx: Black. Identifying mark: on the back of the neck, from frets 0 - 5, are some in-the-wood marks. This instrument was for sale by Southside Guitars in Brooklyn, New York. For a while, they also had No 016 (the only Sunburst Headstock one I saw.) https://reverb.com/item/351788-mosrite- ... 1976-black
NO xxx: Black. Belongs to Kevin Kinney, of Drivin N' Cryin. I'm not sure what its # is. Kinney also owns other Mosrite guitars.
NO xxx: Black. Mentioned at the Marshall Amp Forum in 2020. Owned by one Barry A., and he inherited it. He's had it since 1994, at least. https://www.marshallforum.com/threads/y ... st-2040766
NO xxx: Black. Played by John Reis in 2017. Pic and page saved. Link: https://www.instagram.com/p/BQwF5hQhgXj ... =otisserie
NO xxx: Black. Used in the band Hole in 1990. Youtube video of Hole playing it in 1990: https://youtu.be/vKJCQHxwcms?t=528
NO xxx: Red body and neck. Pics and page saved. Sold from Red Pyramid, in Seattle. https://reverb.com/nz/item/6282103-mosr ... ck-vintage
NO xxx: Red Burst. Seen "in the UK magazine The Guitar Magazine, in the collection of Ross Godfrey, who plays with the band Morcheeba." - Sumlin. The issue is from April 2015, and there are two photos of it there. The guitar's also mentioned in the September 2018 issue of "Computer Music." UPDATE, 10 Oct 2021: This guitar has M Knobs, and it's missing the Aluminum String Guide.
NO xxx, Unknown Finish. Owned (or previously owned by) TheGearPage Member "blesscurse."
NO xxx, Unknown Finish with a Vibrato Tailpiece (probably not stock) on it. There's a pic that I couldn't see or download. Owned or formerly owned by Forum Member "Gibby347." viewtopic.php?f=4&t=5839&p=60251#p60251
NO xxx: Black Body, Black neck, and Black Headstock; very unusual. Has a "Black Widow Pad" on the back, and it doesn't have any M Knobs, so it's a late one. Pics and page saved. Was sold by Austin Vintage Guitars in Austin, Texas. https://reverb.com/item/2842098-early-1 ... -rare#full
NO xxx: Black. This should be a later one, somewhere after NO 0180; it has a pad on the back, and it does not have M Knobs. The listing doesn't say the number. https://www.vintageandrare.com/product/ ... lack-65471
NO xxx: Red. Could be NO 1x8, or NO 1x1. The photos don't show the serial number area clearly enough for me to tell much. https://cartervintage.com/shop/mosrite- ... RjjINZb8Cy
NO xxx: Red Burst. Has Non-M Knobs, so it's probably a late one. Posted at Ben Owens Music, Inc. on Facebook on 16 August, 2023. https://www.facebook.com/benowensmusici ... GAgQwdrhDl
Total:
This list is up to 72 individual guitars (or fewer, depending on ones in the unknown # section.)
48 with Numbers,
2 with partial numbers,
2 with a speculated number,
5 with no numbers,
16 unknown.
Original Finishes (and variants) Accounted For:
Red/Cherry Burst. (Only a few are known.)
Red. (Only a few are known.)
Black ("Dark Burgundy".) Most common finish.
Black with Sunburst Headstock: NO 016. May be the only one.
Black with Black Neck and Headstock: Only 1 is known, and it's late in the production run (evidenced by the black widow type pad on the back,) but its number isn't known.
Brown. Second most commonly known finish.
Translucent Brown. Only 1 is on the list, NO 180.
Sunburst. Only NO 172 is known, but I have no pics. May or may not be original.
White. NO 140. May or may not be original.
Preview Image of a Mosrite 500 Blues Bender for Facebook:
Recent Updates:
5 July, 2023:
29 July, 2023:
19 August, 2023:
7 February, 2024:
8 February, 2024:
22 February, 2024:
3 April, 2024:
28 April, 2024:
29 April, 2024:
21 September, 2024:
28 September, 2024:
Reddit:
24 July, 2025:
Model Trivia:
Basswood Body
Zero Fret
Phase Switch
1: Body Finish.
N)
NO 083: Red.
NO 172: Sunburst.
Total:
48 with Numbers,
5 with no numbers,
16 unknown.
- 101Volts
Bump to notify myself to update this topic.
Edit: I just made a new topic instead.
Users browsing this forum: No registered users and 185 guests
