"Monster Amps" back in the day??
drbassman wrote:dubtrub wrote:drbassman wrote:Since we've been talking truss rods in my thread, I was wondering what you had to repair on your truss rod here?
The adjusting nut edges were rounded off, requiring a new nut. I pushed it out the rear for repair. I found that the rod pieces had been misaligned when originally welded together, so I used the Dremel carbide grinder and cut through the old weld, realigned it and re brazed it.
I hate to be so dense, but when you say "rod pieces" are you referring to rod and the extrenal sleeve? Man this is hard without actually seeing one of these assemblies!
dubtrub wrote:I guess my hopes and ideas are just about exhausted on straightening the bowed neck. I've tried the counter weight for a week now and although I can get the neck straight by tightening the truss rod to the point of striping the threads, there is no way it will remain straight with the tension of four bass strings. I have removed the truss rod and for the past four days I've continued with the heavy counter weight. As soon as I remove the weight, the neck goes back into it's curve. It's too bad I didn't have this project when the weather was running between 103 to 108 degrees. It's just too cool for the weight process to work. This may get put on the back burner until next summer.
Users browsing this forum: No registered users and 719 guests
