'Building' a Danelectro 58 DC
- oigun
Re: 'Building' a Danelectro 58 DC
Way to go bro!! Keep pics comin'
- Olav
The bit I needed
weighed the skeleton
comes in at about 1 kg
va' sa' du? va' hete' du?
my guitars @ LGTf
my 2011TDPRI entry
my guitars @ LGTf
my 2011TDPRI entry
- Olav
used double stick tape to secure the template to the skeleton, coz I'll be manouvring her about quite a bit I think
ALWAYS make sure your router bit isn't touching the wood whan you start the router... I got in a hurry...
darn thing nearly jumped out of my hands
my guitars @ LGTf
my 2011TDPRI entry
my guitars @ LGTf
my 2011TDPRI entry
- Olav
took off the template, found I had used way too much of the double face stick tape
router won't go deep enough
so I had to flip the skeleton over and change bits, that did it though
I'm ready for my close up now Mr DeMille
my guitars @ LGTf
my 2011TDPRI entry
my guitars @ LGTf
my 2011TDPRI entry
Very cool!
woodchuck30
This is kind of kool anxious to see what the final result will look like, if its like your other projects, it will be priety and cool
- Olav
I'm actually kinda on my own here, this is my first project building a guitar.
Oigun is in on this, but busy doing a couple other projects.
Oigun provides guidance and advice
...and he'll be doing the painting.
Thanks for the kind words everyone.
I'm as anxious as you are...
my guitars @ LGTf
my 2011TDPRI entry
my guitars @ LGTf
my 2011TDPRI entry
- Olav
Glued the skeleton
Be sure to rub that out and let it sit for a couple minutes
Then clamp the thing, check the top don't slide off, use pieces of scrap wood to prevent the clamps from indenting the top and back
my guitars @ LGTf
my 2011TDPRI entry
my guitars @ LGTf
my 2011TDPRI entry
- Olav
I made a couple booboos along the way.
1) I neglected cleaning the glue spills when joining the two 18mm skeletons
2) I neglected to clean the glue spills when glueing the top and back on the skeleton
Made for a couple dozen runs that made routing the top/back to size along the skeleton... hmmm... an interesting experience.
Body came out looking like it had goose bumps if that makes sense.
Wound up having to 'dremel' sand those off.
3) Neglected to check router depth between runs when rounding of the edges. For some reason the router bit slipped inside the lock and routing depth ended up being a fraction of a mm deeper the second sweep. Made for a 'nice' snipe (I think you call it) that had to be sanded down. By hand. Don't wanna ruin the edge by using a sander.
OK, that's enough for confession time.
Here's some pics.
routed to size
goose bumps
dremel sanding bumps and glue runs off
rounded off
centre lined
weighed
the net I used will have added maybe 100 grams
comes out just under 2kg
Tomorrow I'm routing the neck pocket at Oigun's. I need the neck to create a tight fit. The tighter the better. Neck needed a bit of a touch up here and there.
So... updating tomorrow night.
Here's some pics.
routed to size
goose bumps
rounded off
centre lined
weighed
my guitars @ LGTf
my 2011TDPRI entry
my guitars @ LGTf
my 2011TDPRI entry
It's looking great! Well done.
Users browsing this forum: No registered users and 224 guests
