Bass Time!
Re: Bass Time!
just wondering if you remembered to tape off the neck pocket before spraying?
- oigun
Re: Bass Time!
oipunkguy wrote:just wondering if you remembered to tape off the neck pocket before spraying?
Nope. The pocket was really tight but there is only a little paint coming in the neckpocket so when I use 2k I dont bother.
When using nitro I tape it off for sure becaus it can cause problems later when removing the neck.
Ok, wood on wood for better tone etc.... that discutable
- oigun
Re: Bass Time!
yesterday I plated the last parts. Unfortunately the nicckel platong on the unplated knobs will not work. Plating potmetal is a different process and I have to figure out the right steps..
I had to make some changes on the bridgeplate so I replated that.The surface rust is from the acid dip wich I didnt rine properly so I had to do that again.
The body is attached to the neck and I did some spit&polish
Also made the stringguide, the tunerbushings came out great!
- oigun
Re: Bass Time!
Polished up the tuners and reamed the bushings for a perfect fit.
Re: Bass Time!
That looks awesome!
saf
Re: Bass Time!
smokin'hot
Re: Bass Time!
sweeeeeetttt!
Re: Bass Time!
Really cool...and the (darker) blue finish is absolutely gorgeous after all. The surface is so beautifully smooth...professional job man!
http://www.mijnalbum.nl/GroteFoto-RPKEG7CR.jpg
- oigun
Re: Bass Time!
Today I finished the pickup. And corrected the headstock the tunerholes were not evenly spaced towards the edge. So I sanded 2mm of one side (otherwise it will haunt me)
Installed heightbar and drilled the holes in the ring.
Just for fun I put on every part the cerialnumber
Scratchplate mint or aged white?..... Its gonna be AW
Re: Bass Time!
Wow, it's like Mosrite is being manufactured in Holland...
We're proud of you oigun. If I had the money, I'd ask you to make a guitar for me, if you were willin'
Users browsing this forum: No registered users and 636 guests
