Star Swirl *** 1st build
cmiller0034
Re: Star Swirl *** 1st build
Postby cmiller0034 » Tue Jul 15, 2014 9:10 am
Riddle me this
At the sound of me, men may dream or stamp their feet.
At the sound of me, women may laugh or sometimes weep.
what am I?
panther wrote:MUSIC.
Dan you have earned the Greatest gift of all
All hail Dan, his wisdom has saved us from the end times. May our children and children's children tell of Dan's deeds and cunning forever more.
Postby panther » Wed Jul 16, 2014 10:18 am
Talk about a coincidence.
I belong to an acoustic Guitar Forum.
Note the Avatar photo...Creepy...
cmiller0034
Postby cmiller0034 » Thu Jul 17, 2014 4:13 am
panther wrote:
I Google d Panther, out of all the search results that came up that one just popped out at me. That image must have some kind of appeal on a subconscious level. It certainly is Creepy, that why I choose it. Yeah that's Weird.
also
I REPAIRED MY TOILET PLUMBING
but this is the Mosrite Forum so I wont share any details on that
I also
BUILT A FRETBENDER
Out of skateboard bearings, lock washers, 2 Fender washers, and 8 mm bolts.
$125 you gotta be kidding StewMac
The slotted hole was cleaned up with the router. With a wing nut, I can adjust the radius of the bend.
cardboard in between the washers creates a channel for the fret tang to ride along
My tri-flow lubricant also showed up, now the Tuning Machine heads turn smooth as silk 8-)
cmiller0034
Postby cmiller0034 » Mon Jul 28, 2014 9:41 pm
A little Fret TREBLE
Well I have been a busy busy bee. Here there and everywhere on this guitar. My plans for the body have changed Drastically. While I wait for Hide glue to dry, thought I'd make and update.
FYI: The Sanding blocks the LMI sells are not exactly 12 inches in radius they are more like 11 inches. I trust the brass fret press caul inserts from StewMac for than LMI's woodblocks and the woodblocks are off. This makes my job harder.
I finally made the investment into StewMac's Dremel Inlay tool. I have been making great use of it.
More FYI: These bits are advertised by Stewmac to be narrow enough to clean out fret Slots.... No way. Well maybe some Gigantic bass wire of some sort not with the slots I'm working with.
You can see the impressions left by the bit. Way too big for the slots. I quit while I has ahead and went the traditional method of deepening the slots.
Cutting the slot for the Brass string guide from Mr. Shade. Using this Awesome Upspiral bit.
I was having trouble getting the String guide to sit flat until I used this square rifle file.
NOTE TO SELF: The String Guide and all the Frets should be moved up the neck on the next Build.
I wanted to but my StapLocks on my body temporarily, so I drilled.
Ground some fret nippers. Put a handle on my fret bender. I know Stainless steel it rough on tools these claim to be Drop forged whatever that means. Hardened steel I guess. I have not noticed any nicks on the cutting surface yet, so that's good.
Made a fret press Caul holder. These inserts are one of the few things on StewMac reasonably priced and they are VERY useful. The caul holders however are very expensive and you can make your own. I plan to redesign mine but the simple design will do for now.
Angle for "string dropoff" was increased.
angle blended in with headstock
I'm tired. And have alot more pics and story of how I messed up and had to fix some frets on installation. Takes alot of time to upload these photos, Ill get back to it later.
cmiller0034
Postby cmiller0034 » Tue Aug 05, 2014 3:30 pm
wait... what?
Stainless Steel. You've met your match
Not my Idea. Props to this kid.
A time consuming method. But with patience comes great results.
First few went in great. Then I got cocky and messed up the next 3 frets. Had to take a day and repair the slots.
1 Cut off file
2 stick file in scrap 2x4 at 45 degrees
And so here we are. Lots of work left to do. I just wanted to test the guitar and make sure the scale length was measured right. Well, it measures at 24-1/2". (yes shorter than the already short scale 24-3/4" ) Its my first guitar, I was bound to make plenty of mistakes. :lol: The Fret spacing is correct thought, albeit a bit cramped for my fingers higher up the neck. I will make the neck a standard length on my next neck.
Starting to look like a guitar, huh?
BRRanger
Postby BRRanger » Wed Aug 06, 2014 5:42 am
Lookin' good!
Scott
Greg_L
Postby Greg_L » Wed Aug 06, 2014 9:19 am
I really enjoy following your build. I'm impressed with the way you just make things and make things work. Keep it up.
cmiller0034
Postby cmiller0034 » Fri Aug 15, 2014 4:54 pm
Greg_L wrote:I really enjoy following your build. I'm impressed with the way you just make things and make things work. Keep it up.
Lookin' good!
Scott
Thanks Guys I appreciate the encouragement. Sorry I haven't made any progress updates in a while, I have had to deal with an Avalanche of "Issues lately"
Warning! If you don't like to listen to people whine about their trials and tribulations please skip over the next few paragraphs.
For those following my posts you are probably aware that I own a pretty crappy car that tends to bread down and leave me stranded quite frequently. Well it finally gave up the ghost last Wednesday. I went to see Guardians of the Galaxy last weekend and just as I came off the expressway onto an 8 lane highway, when the distinct aroma of burning oil and all things unholy started to offend my nostrils. The car almost made the turning light but not quite. I sat there for about 6 or 7 minutes with irritated Mall-goers driving around me until a kind gentleman with a young boy helped me push my smoking hulk into a nearby parking lot. The car had been suffering from a mysterious oil leak, which I could not pinpoint the source. I guess filling the engine every two weeks with oil was not enough because the old heart had run dry, there were metal shavings in my oil pan... Now I need a new car. (preferably a reliable one)
So I got the old trashed Motorcycle back out of the garage. Which had been sitting there since March when I broke my hand in two places on it, and went about getting it ready for work (my job was resuming again after a summer recess and I needed SOMETHING). It had a slight oil leak of which I tried to repair by tightening up the copper crush washers on the oil pipe. Took it for a test ride to my buddy's house in the country side. Got on the off ramp of the expressway and slowed for the stop light. The bike stalled. No prob, Ill just restart it..... Nothing, the bike wouldn't turn over, I was getting nothing from the starter, everything else had power so it wasn't the battery and the fuses were fine. So after about 10 minutes of trying to push start the thing and looking it over, I decided to push the lump of iron to my friends house, he is a Mechanic and I would be able to fix my bike properly once I got to his garage. Unfortunately that required pushing a 500 pound motorcycle about 1/2 mile up and down hill on a country back road, with only 2 lanes and no shoulder with a fractured left hand in 90 degree heat.
Well, to make a long story short I left my bike over my friends house, got a ride home. Took my starter home because I needed the bike for work the day. Spent about 6 hours working through the night to rig the worn out brushes on the positive leads to work. Atleast until I could get a proper starter repair kit with new brushes trough the mail. I used some 22 gauge eyelets and sandwiched a couple of ill-fitting spare brushes from a hand grinder into my starter. Fortunately it has lasted me the workweek. My starter repair kit came through the mail today so I will be taking the thing back off the bike and properly fixing it this weekend.
The culprit. Worn out brushes on the positive terminals.
Last night someone broke into my Garage and my what's left car, and stole my Mother's bicycle but left my tools. This leaves me very confused. :? I hope they weren't "scouting" and intend to return. Any way we have to reinforce to window the thieves pried open. And I'm going to put my router and other valuable tools in the house. This neighborhood has gone to the dogs in the past 10 years. :( I Would leave if I had the scratch.
When it rains it pours :lol:
Anyway hope to be working on my guitar again soon. Now that work is back in swing maybe I can save for a car before winter sets in an I have a repeat of last winter. I dont want to break my other hand before this one is healed yet!
Thanks for the encouragement everyone.
Postby panther » Sat Aug 16, 2014 9:59 am
I notice you use your drill press for a regular press. I used mine for years. It was a floor model My Dad had years before me. I was pressing in the saddle studs on "MY Mosrite build", when WHAM, I snapped the cast iron mounting bracket that hold the drill press table to the upright pole. BE CAREFUL.
Cast iron IS NOT EASY TO REPAIR.
BRRanger
Postby BRRanger » Sat Aug 16, 2014 10:51 am
Yikes! Imagine the bracket busting and the guitar body falling to the floor! Sounds like something that would happen to me. Good safety call!
Scott
Users browsing this forum: No registered users and 510 guests
