style" mosrite of burgundya"
ludobag
Postby ludobag » Sun Aug 26, 2012 7:30 am
routing is done
and the error from yesterday will go in the carve :)
now i have the profil to do and i really don' t know how?
i can't trust my band saw :evil: and for the head i don't have idea how ?
ludobag
Postby ludobag » Sun Aug 26, 2012 9:18 am
i have some trouble to trace the headstock du to curve
there is a technic for ?
i have trace it 4 times and at each i have an offset ?
for the rest of the neck i have find how to do but this part is not easy :|
ludobag
Postby ludobag » Mon Aug 27, 2012 12:12 pm
not do enought cause i am ill :evil
and i trace the headstock normally it will e good i will shape after the fret board glued
tomorrow if i can i try to make the heel and the profil
ludobag
Postby ludobag » Tue Aug 28, 2012 12:16 pm
pick up template
neck pocket
fretboard glued
heel and volute at 35mm and neck profil at 16mm
:roll: must do my roller string guide or the technics of the fret (it is more easy in fact :lol: )
ludobag
Postby ludobag » Wed Aug 29, 2012 11:00 am
fretboard ,binding channel ,space for the pup miss only the 2° on this side
rest some work on this one :o
tomorrow shaping of the head and radius
ludobag
Postby ludobag » Thu Aug 30, 2012 12:50 pm
heel is finish
the head need a more high curve (when i have my string t) and the volute will be finish after the radius ,i need this point to have my neck straight
radius beguin at 8o grit i have stop cause it is not easy in the night :lol:
moreover tomorrow i must drill and glue the dot before continu
ludobag
Postby ludobag » Fri Aug 31, 2012 2:27 pm
Postby MWaldorf » Fri Aug 31, 2012 10:06 pm
Looking good!
peterbright
Postby peterbright » Sat Sep 01, 2012 6:33 am
It seems like a lot of work. Good luck.
ludobag
Postby ludobag » Sat Sep 01, 2012 3:25 pm
just a little cause i was busy
i ll be carefull for the neck pocket hopefully cause normally 25mm then i made mine at 21mm
and with a straight edge it seems to be good ,i will see after the neck will be completely finish cause with 2mm of fret and 1mm of high of string surely need to made it deeper
then on my mdf guard of 3mm
without
if a gentle forumite can tell me the high of the mosrite neck just before the pups on the side without the guard or with (but with the tickness of the guard )it can help me a lot cause i have seen lot of pics and none look the same :shock: (that why you know they are hand made in fact :lol: )
maybe my 2° are wrong and moreover rest to finish the neck before ajust the all things ;)
Users browsing this forum: No registered users and 439 guests
