Mosrite Serenade models (Acoustics) Serial Numbers #s List (1960s.)
Re: Mosrite Serenade model (Acoustic) Serial Numbers #s List (1960s.)
Postby 101Volts » Sun Apr 27, 2025 8:44 am
duojet55 wrote:Here is my Serenade, F 0213. I got it on 11 June 2021. Other than a few minor scratches, small dings and a few places of lacquer checking, its finish is in really nice condition. It does have a pretty high action but is still quite playable in the lower register. For a smaller body, this guitar is LOUD! The neck is a set neck, but there is a small screw through the neck block inside the guitar.
Thanks. I had it in the list already, but without a photo and I didn't know the finish.
I also had forgotten to mention in the main topic until now that the Serenade isn't exactly a "set neck," and Jack Wildwood told me that the one screw is there so you can adjust the neck angle and lock it in place. So it's like the old neck tilt system seen in a 1930s Kay Kraft Banjo.
duojet55
Postby duojet55 » Tue Apr 29, 2025 10:13 pm
Wow! Thanks for the info. I'll see if I can get the action down. I really love this guitar and have wanted one for a long time. I just don't play it as often as I'd like because of the string height.
Here are better front and back pix of the Serenade from the folks I acquired it from, Nationwide Guitars.
duojet55
Postby duojet55 » Wed Apr 30, 2025 1:55 pm
I just closely inspected my Serenade. The slotted screw at the neck block is simply for neck reinforcement. The neck pitch cannot be adjusted, unfortunately. There is unbroken lacquer between the neck heel and body. Nice idea, anyway. I guess I'll need to send it off to a luthier for a proper neck reset. :(
Postby 101Volts » Thu May 01, 2025 11:56 am
duojet55 wrote:I just closely inspected my Serenade. The slotted screw at the neck block is simply for neck reinforcement. The neck pitch cannot be adjusted, unfortunately. There is unbroken lacquer between the neck heel and body. Nice idea, anyway. I guess I'll need to send it off to a luthier for a proper neck reset. :(
Oh. Darn. I'm not sure why Jake was telling me that, then. He might be thinking of something else, but with Mosrite history being as incomplete as it is, maybe he did see a Serenade or Balladere with that feature.
Re: Mosrite Serenade models (Acoustics) Serial Numbers #s List (1960s.)
Postby 101Volts » Wed Aug 13, 2025 7:28 pm
Update to the main topic made today.
Postby 101Volts » Sat Aug 16, 2025 6:47 pm
As it turns out, the "Serenades are not exactly a a set neck" thing is probably about one of the later Serenade models. When I posted earlier, I thought it was applying to the Serenades with a serial number prefix of "F," but there are at least 3 other types: "FE," "FG," and "FH." Very few of these have shown up so far, and Jake Wildwood worked on one of the "FE" series models.
This reply's also here to bump up the topic for August 16.
Postby 101Volts » Mon Oct 13, 2025 11:21 am
Bump to the topic. FH-8119 has a small update.
Users browsing this forum: No registered users and 185 guests
