Mosrite Mark I Tremolo Setup
Texasbob
Re: Mosrite Mark I Tremolo Setup
Postby Texasbob » Sun Dec 14, 2008 1:10 am
Texasbob wrote:That's a drag about the tailpiece gap. That's a pretty big design flaw. I had to change the spring on my Fillmore from the stock 60lb spring to a 120lb spring. With the 60lb spring and 4 shims, once the .050 low E was put on then the spring took a dump. With the 120lb spring and 0 shims it sets perfect to my taste and back to where it should be if given the lighter guage strings. ;)
If anyone is interested in the heavier spring tension for heavier guage strings let me know. The gentleman I mentioned that helped me out is about place a minimum order of 40 springs so I'll have one for my doubleneck too. :)
If it hasn't been done before, there's a reason why.
brunob
Postby brunob » Sun Jul 05, 2009 2:20 am
now I'm discovering some others "little" things....
are there some others way to eliminate that "move"?
are all the others brand tremolo the same? :evil: :shock:
I've to find it out,'couse this is the main problem to go out of tune,I think.
Bruno
Postby 101Volts » Sun Jul 05, 2009 9:23 am
While we're somewhat on the subject of tuners I haven't ever seen anyone put Steinberger tuners on their Mosrite. Is it just that nobody on the forum has tried them yet or do they make the guitar "headstock heavy"? Or do they not fit?
Postby Dennisthe Menace » Sun Jul 05, 2009 10:45 am
101Volts wrote:While we're somewhat on the subject of tuners I haven't ever seen anyone put Steinberger tuners on their Mosrite. Is it just that nobody on the forum has tried them yet or do they make the guitar "headstock heavy"? Or do they not fit?
The only Tuners I recall from Steinberger mounted at the butt of the guitar, sort of like the Floyd Rose, but not on the bridge. If those are the ones you are talking about, it will create havoc with your TREM system, being that it would have to......no, that won't work. I don't think you want to start cutting up your guitar just for those tuners..... :shock:
Postby dorkrockrecords » Sun Jul 05, 2009 10:52 am
Nah, he's talking about the Steinberger gearless tuners. Good tuners, just not sure about them on a Mosrite...
http://www.stewmac.com/shop/Tuners/Guit ... uners.html
Postby thunderhead » Sun Jul 05, 2009 11:31 am
I originally tried using the bigger strings on my Mosrites but found out for what I'm after the lighter strings work better. That was also one of the factors that attracted Nokie Edwards to Mosrites also, they worked great with light strings. My original 65 Ventures and Jonas Ridge Side Jack Ventures both stay in excellent tune with stock parts and setup. I work them hard and do a lot of "Dive Bombing" ala The Ventures "Driving Guitars". Also my Hallmark is equally as consistent and reacts well to light strings and heavy tremolo work. I love the nylon washer mod and will check out the space, if there is one on my Guitars. thanks for the tip and beautiful pictures of your Mosrite.http://www.myspace.com/thethunderheads
Postby oipunkguy » Sun Jul 05, 2009 12:23 pm
interesting stuff, and way awesome pics! on my moseley tremolos I never had this issue. I use 9's and 10's on my mosrites, but never had any issues with the tremolo unit shifting on me.
brunob
Postby brunob » Sun Jul 05, 2009 1:36 pm
mmm,no matter about string gauge,we're talking about the tremolo unit movin',and pull the strings out of tune while playing.
we are gonna fix this issue too!!!!!!!!!!!!!!!!!!!!!!!!!!!
Bruno-a 60's guitar lovers- :twisted: :twisted: :twisted:
Postby 101Volts » Sun Jul 05, 2009 3:43 pm
dorkrockrecords wrote:Nah, he's talking about the Steinberger gearless tuners. Good tuners, just not sure about them on a Mosrite...
Yes, Those are the tuners I was referring to. I suppose we could answer the question by finding out if people put them on Gibson guitars with angled pegheads.
Postby oipunkguy » Wed Jul 08, 2009 6:14 pm
the reason why i mention the string gauge is because there would be more movement in a bridge sysytem with less tension. But even when I have no strings on, the whammy doesn't shift on me.
I don't have any tuning issues on my mosrites, even when i use the whammy a lot. the only thing I would suggest is that I switched out my tuners to grover rotomatics, and I personally I feel they help with tuning stablity compared to the vintage style klusons. Just my two cents.
Users browsing this forum: No registered users and 50 guests
