Problem with my Hallmark
Greg_L
Re: Problem with my Hallmark
Postby Greg_L » Sat Feb 14, 2015 8:09 pm
Yall jinxed me! Last night I popped the ball end off of my B-string! :lol:
I've been meaning to switch to 9s anyway, so that's what I did. I tinned the twisty ball end for extra support and the 9s are on. I like them better so far. I found the 10s were a little stiff for bending on the 60C for some reason. The 9s on this guitar feel more like my SGs and LPs.
cincinnatiharry
Postby cincinnatiharry » Wed Mar 04, 2015 5:05 pm
Soldered the strings, worked perfect. Thanks all!
Tom From Vero
Postby Tom From Vero » Tue Feb 28, 2017 2:11 pm
Same issue with my Custom 60 - Ernie Ball Slinky 9 gage would occasionally unravel at the ball. Just before a string change, try one small drop of Crazy glue gel on the wound part that unravels. You will no longer have this problem.
Postby Bob Shade » Wed Mar 01, 2017 5:05 pm
Good idea! Stevie Ray used to have his tech solder the ball ends. I think super glue would be the next generation fix. GHS reinforced ball end strings will not break if you don't want to glue or solder the ends.
I think all strings should come pre-stretched with reinforced ends. That would be perfect.
Dickey
Postby Dickey » Sun Apr 01, 2018 8:34 pm
That's happened a couple times with my original Ventures '65 Mosrite. And, only after I loosened the string a couple times to fix something on the bridge. Hasn't happened since.
amoviebuff
Postby amoviebuff » Mon Feb 04, 2019 6:25 pm
No comment on the string issue, but your guitar is a real beauty!
Don
_______________________
2019 Höfner HI-BB Bass
2019 Hallmark 65 Custom
2018 Fender Mustang 90
2002 Fender DG-11
1993 Fender Strat Plus
1972 Mosrite Mark I
1968 Mosrite Ventures
1968 Vox Folk Twelve Electric
Daggerwolf138
Postby Daggerwolf138 » Fri Feb 15, 2019 6:23 am
I have this same problem from time to time. So I always chalks dit up to a bad string. Ie recently just found and purchase Ernie Ball reinforced slinky’s that I’m going to put on next string change.
Return to “Hallmark Guitars”
Users browsing this forum: No registered users and 177 guests
