Switching pot values on a Hallmark 60's Custom.
halfpast
- Grizz
Re: Switching pot values on a Hallmark 60's Custom.
Thanks for that!
I don't really dabble with the electrics of my guitars, if bought two can I use these type of pots for both tone and the volume? Do you need a certain type of capacitor too (ie a .22 or .47) or can I continue to use the one that was installed with my 250k pot equipped 60C?
615n8
Sometimes you'll see and audio taper pot (volume)and a linear used (tone). Either of those caps would be fine, they affect the way the tone control works. You may want to try them all while you're sound the pots (not at the same time)
- Grizz
615n8 wrote:Sometimes you'll see and audio taper pot (volume)and a linear used (tone). Either of those caps would be fine, they affect the way the tone control works. You may want to try them all while you're sound the pots (not at the same time)
Cool, thanks for the advice - much appreciated!
615n8
- Grizz
615n8 wrote:Da nada.
Got two of the vintage CTS audio taper pots in a few days ago and a 0.22 cap - I had to make the holes on the 60C scratchplate a tiny bit larger to accomodate the slightly larger thread on the CTS pots but all works great, thanks again for the good advice folks.
Users browsing this forum: No registered users and 214 guests
