Help on pricing for a '65 or '66 Combo
jeffee
Re: Help on pricing for a '65 or '66 Combo
Postby jeffee » Thu Apr 11, 2013 1:42 pm
yeah that's what i've figured out based on other models and years.
but of course there's no rhyme or reason sometimes.
i would guess tho that they wouldn't be using mid-65 pots past maybe a year?
jeffee
Postby jeffee » Thu Apr 11, 2013 10:19 pm
one other "odd" thing about my combo
the serial number on the sticker in the F-hole says: H-0970
but on the fretboard it's stamped: H 0 9 7504
(and extra 5 and 4 were tucked in there between the last 2 numbers)
it's got pots from '65 / no neck plate (just 4 bolts) and no ® on the pickups- just the mosrite logo (meaning earlier pickups)
4th Dimension
Postby 4th Dimension » Tue Apr 16, 2013 8:31 am
Thanks everybody for all the great information!
I think I might hold off on the Combo in my area and try and wait until I have the money together for a nicer example.
Either way I go I'll let everyone know when I acquire one!
Cheers!
-4th Dimension
4th Dimension
Postby 4th Dimension » Fri Apr 19, 2013 6:06 pm
Bob Shade wrote:The trem pulling up should not be an issue. You can get a quality hardwood dowel and drill a clean hole for it (larger than the screw) and re-drill the holes for the tailpiece.
By the way we have the arm you need for that tailpiece too.
Hi Bob,
I'd need an arm , spring and whatever else would be needed. What would the cost be?
Thanks!
Kevin (4th Dimension)
4th Dimension
Postby 4th Dimension » Sat Apr 20, 2013 5:08 pm
https://skydrive.live.com/embed?cid=0C65BDA11B4B178F&resid=C65BDA11B4B178F%21222&authkey=AD8ZPtXEeEcx4hM
Evening all,
Well I bit the bullet and bought the Combo in my local area. After looking it over again for the second time, It's not anywhere near as bad as I thought. I got a quote of $75 for the doweling and resetting of the tremolo and a basic tuneup. I'm very excited that I followed through and bought the guitar. Can't wait to get her strung back up and let the first chords ring out on this soon to be resurrected beauty!
-4th Dimension
Postby MWaldorf » Sat Apr 20, 2013 9:51 pm
Cool - congratulations! Let us know how the repair goes. Great that a vintage Mosrite will be returning to playing condition.
Postby Bob Shade » Sun Apr 21, 2013 5:56 am
Congrats on the Mosrite score!
The arm including the screw and special washers is $69.00 plus $5.00 shipping. You can Paypal me directly @ shadeplus3@aol.com.
If you decide you would like to save the $75.00 on the repair, it is a simple one. Get a hardwood dowel that is a snug fit in the existing hole, or you can but one a hair larger and re-drill the hole. Cut sections about 1/4" long and take some wood glue and tap them into place. Let the glue dry, then drill the holes for the screws ( smaller than the screw) and re-mount the plate. It will cost you about $2.00 for the dowel and a little glue and about 15 minutes of time.
Good luck and let me know if you have need any more advise or parts.
4th Dimension
Postby 4th Dimension » Sun Apr 21, 2013 1:47 pm
Bob Shade wrote:If you decide you would like to save the $75.00 on the repair, it is a simple one. Get a hardwood dowel that is a snug fit in the existing hole, or you can but one a hair larger and re-drill the hole. Cut sections about 1/4" long and take some wood glue and tap them into place. Let the glue dry, then drill the holes for the screws ( smaller than the screw) and re-mount the plate. It will cost you about $2.00 for the dowel and a little glue and about 15 minutes of time.
Thanks for the advice Bob!
I was initially adverse to drilling out the holes myself considering it's a vintage piece and I just put all the money I had from selling my Jaguar into it, but I got the nerve to do it myself anyway. I know it's not rocket science but... taking sharp rotating cutting blades to a vintage guitar that's not easily replaced makes me a little nervous ;)
I had to drill out the holes to 5/16 because the plate screws had pulled far forward. On my way to get some 5/16 hardwood doweling cut to size now and glue those suckers into place!
Have a great afternoon!
-Kevin
Users browsing this forum: No registered users and 127 guests
