Scrap Aluminum Vibrato
Butch
Re: Scrap Aluminum Vibrato
Postby Butch » Thu May 24, 2012 6:41 am
MWaldorf wrote:Wow Butch, that looks great. Did you use an angle grinder or a dremel or something else?
I used an electric scroll saw, table saw with a 60 tooth carbide tip blade, drill press, belt sander and micro mesh sanding pads.
The bearings are a little bit bigger than standard Mosrite issue, 1/4" ID that I found at the local hardware store,but they seem to work OK. I dont know if I will ever use it on anything.......ya know , more like an experiment.
Postby olrocknroller » Thu May 24, 2012 8:17 am
Butch wrote:
olrocknroller wrote:Nice job! Be prepared to "beef up" that spring... ;)
That was the only spring I had.......where do I find a "Beefy" one ?
I have seen a rubber bushing used on a Canadian built guitar, built by Bob Gander http://www.ganderguitars.com/ ...might be worth a try, since you're experimenting.
ludobag
Postby ludobag » Thu May 24, 2012 9:44 am
looks really good ,this week i have put eyes on it but not beguin again too lazy :oops:
the thing who is boring me is the 2 hear haven't the same size in larger on my drawing then i must adapt it after i made the rocking part ;)
and there is 2 type, the vibramate and the the mosley what too choose ?
i prefer the vibramate but i have more cotation on mosley :|
Postby oipunkguy » Thu May 24, 2012 4:44 pm
this is great, i might even want you to make me one! ;)
