6G6-B Bassman clone project
Re: 6G6-B clone project Question
Postby JimPage » Fri Apr 06, 2012 6:53 pm
Hey, Danny--
Let me discuss this with someone more knowledgeable on silk-screening than I am. I've made plates or negs for use in silk-screening, but have only once seen it done.
But that's the last step, any way!
Postby MWaldorf » Fri Apr 06, 2012 8:35 pm
Looks like a great project Danny - I'm excited to see how it progresses!
Postby Mr. Bill » Fri Apr 06, 2012 9:10 pm
Danny, try ezscreenprint for a simple screenprinting system. Jim, most screenprinters require right reading, emulsion side up, film positives to burn their screens.
Postby JimPage » Fri Apr 06, 2012 9:52 pm
Mr. Bill, thanks for confirming the RREU pos info!
I'm going to look into the ezscreenprint system, too, thanks to your tip. Danny, here's the link:
http://ezscreenprint.com/
Postby dubtrub » Fri Apr 06, 2012 10:09 pm
Graphics and printing is out of my league. I'm having a hard enough time trying to teach myself electronics. Just spent the last three hours going over the layout and comparing with the schematics in order to make up a parts list. Man, this stuff is mind boggling. I'll leave the art work to someone else.
Postby JimPage » Fri Apr 06, 2012 10:26 pm
My best friend and former band mate, going back to junior high days, builds amps. His latest was a 5E3, I believe he said, and he put it in an old Crosley radio wooden enclosure. The eight-inch speaker fit nicely in the cathedral hump part and he built this as his bedroom guitar amp.
Or, at least, that was his plan until his teenaged son snagged it for his room!
Postby dubtrub » Sat Apr 07, 2012 12:08 pm
Mr. Bill, can you check the value of the cap on the board from pin 7 of the rectifier tube, both schematics and layout shows a .1-200 capacitor. I'm guessing it's an error on both schem & layout and should be a 0.1uF as are the other two off pin 6 & 1. Can you verify and recommend a alternate?
Re: 6G6-B Bassman clone project ?
Postby Mr. Bill » Sat Apr 07, 2012 9:42 pm
I guess I don't understand what you are asking here. I think that you are talking about the driver or phase inverter tube that drives the output tubes. There is no rectifier tube in this version.
The cap you are refering to is part of the negative feedback circuit and is normally a 0.1uF at 200 volts. I will open up my amp and confirm this, but that is the normal value for this part in almost all Fender amps.
If you can rephrase your question I will try and give you a better answer.
Postby dubtrub » Sat Apr 07, 2012 10:32 pm
You are correct. Phase inverter not rectifier tube. I've been studying this stuff so much the last couple of days trying to translate 1962 values with all them zero's to current marked capacitors, my head is swimming. Please don't go to the trouble of opening up your amp.
Postby dubtrub » Wed Apr 11, 2012 2:17 pm
Mr. Bill, referencing the two .25 capacitors on the right end of the main circuit board to the bass pot, will .22 caps work there as I was unable to obtain those two caps with .25 value?
http://ampwares.com/schematics/bassman_6G6-B.pdf
Got all the parts ordered today. Should be able to start building once they arrive.
Users browsing this forum: No registered users and 679 guests
