leftyjay wrote:first off, i have a sunset green and a pearl white lefty custom 60 guitar. i feel fortunate to have 2 of the first run of lefties ever made. the guitars are really nice. just a couple issues i've noticed that seem odd. dont know if this is the norm on all custom 60s or just on the lefty guitars.
i was noticing that my cowboy chords seemed to be out of tune from one chord to the other (G, C, D, A, E, etc). plus the action is quite stiff because of the string height over the zero fret. I was looking at both my custom 60 guitars and noticed how much higher the zero fret is compared to the regular frets. both of the guitars have considerably high action at the first fret. this is usually the reason for the first fret being sharper in pitch when fretted and the action stiffness.
i have a couple other guitars with zero frets and the action is real low at the first fret. my gretsch 6120-60 has a zero fret, but the zero fret is the same size as my other frets. after doing some searching online, i notice that most zero frets are slightly higher than the regular frets, but the Custom 60s are extremely higher.
did this issue get overlooked because of it being a lefty? i'm sure i can get the fret filed down to get the correct string height over the zero fret, but i wanted to see if i was the only one that noticed it.![]()
when i play from the 3rd fret on down the neck, the action seems good and the guitar plays in tune.
i was also wondering if the slotted fret at the top was a replacement for the slotted nut that i see on other custom 60s?
plus..., i know these guitars have a slightly wider neck than the mosrite, and the bridge matches the string span, but are the pickup magnets still the span of the original mosrite guitars? the reason i ask is, i noticed the magnet spacing doesnt match the string spacing. i dont really notice any sound drop in the strings that are not lined up with the magnets, but it seems to look off. i was able to look at these guitars at jerrys lefty guitars in sarasota fl and noticed that all the guitars he had, have the same spacing difference.
my white pearl C60 is centered better between the E strings, but does have the same spacing difference. like i said before, the guitars sound fine from string to string.![]()
and finally, the lefty guitars came wired left handed. the only thing is, the pots are righty pots which doesnt allow the volume and tone taper to be smooth. it basicly was all or nothing. i rewired them back to righty (normal) wiring and they work fine.
just wanted to bring up these questions to see if it is just me, or is this the norm on all C60 guitars?
Bob Shade wrote:Originally, the PAF he designed for Gibson had no adjusting polpieces at one end, the metal cover would have covered the pickup with no holes. Ted or someone in charge said why does it not have adjusting polepieces for each string? Seth Lover replied they were not needed. The magnetic field would still pick up all of the sound. The man in charge said, put the adjusting pole pieces in there anyway, it will give the salesman something to talk about. So they did. True story from Seth himself. I guess you catch my drift here.
olrocknroller wrote:My Hitchhikers use the same size zero-fret as the others on the neck, but they are stainless. I notice that these guitars need to have a little relief set into the necks for best playability, so I think the higher zero fret would permit an absolutely straight neck, which a lot of players prefer...
Users browsing this forum: No registered users and 269 guests
