You can also round the bottom first before grinding the teeth.
dubtrub wrote:That's all I've been using for years to cut the slots then I use a torch tip cleaner to round out the bottom of the slot. They can be had for around $6.00 at Harbor Freight.
MissionBrown wrote:dubtrub wrote:That's all I've been using for years to cut the slots then I use a torch tip cleaner to round out the bottom of the slot. They can be had for around $6.00 at Harbor Freight.
Thanks to this post, I got the exact same tip cleaner, and it's a fantastic nut slotting tool
Now I need to find some saw blades, or I might just mod my feeler gauge as shown.
I got Dan Erlwine's "how to make your guitar play great" in the post yesterday, in the back are cardboard versions of stewmac's radius gauges
MWaldorf wrote:MissionBrown wrote:dubtrub wrote:That's all I've been using for years to cut the slots then I use a torch tip cleaner to round out the bottom of the slot. They can be had for around $6.00 at Harbor Freight.
I didn't see the file being sold separately at Harbor Freight. Is this the same thing?
http://www.amazon.com/WYPO-Standard-Tip-Cleaner-Set/dp/B0049WSL2O/ref=sr_1_10?ie=UTF8&qid=1306361696&sr=8-10
Users browsing this forum: No registered users and 579 guests
