Full-Size Vibrato, Finally!!!
- Bigwave
Re: Full-Size Vibrato, Finally!!!
Raygun85...you've out done yourself, awesome job. The vibrato looks Fantastic!!
Can't wait for the unveiling of the 63 American.
Bigwave Dave
1966 Ventures Mk I (My Fav!)
1968 Kustom K200
1977 Les Paul Std
1982 Explorer CMT E2
1982 Gibson V2
1987 Stratocaster
1966 Guyatone Sharp 5
1967 Teisco Vegas 40
1968 Greco Shrike
1968 Norma EG400
1969 Firstman Sharkfin
1969 Guyatone LG250T
1968 Kustom K200
1977 Les Paul Std
1982 Gibson V2
1987 Stratocaster
1968 Greco Shrike
1968 Norma EG400
Dillon
Just wondering, would there be any bridges with Fender-style spacing that would work with these vibratos? I'm interested in getting one for a Jazzmaster project I'm building
- TerryTNM
Nice job! A real neat hand-made look.
Are the string bores staggered or have you made them straight across? I myself would be interested if you could make them straight. The Moseley pieces have uneven down pressure on the bridge because of the high-low bores. When you're working with low angles every advantage must be used. I've talked to Bob Shade about this. I don't want to start up the 'stays in tune better' discussion again
. I'd probably use the Schaller bridge as I do use their string spacing capability and their 14" radius. Would your unit have the same post to post dimensions or be delivered to drill yourself?
A good looking piece!
- oigun
I have it here! Its a real nice piece of ART!! The holes are staggered but I'm sure matt can drill them any way you like.
When I have fitted and adjusted the guitar I will post my findings. But I think it will be great just like Olavs.
- raygun85
Hey Terry, we can drill them any way you like. They come out of the mold without any drilling or milling. We do prefer the Mosrite pattern for the string bores, just as Bob Shade does on his vibrato. However, we hired a machinest a while back when we got behind on some orders and he inadvertently drilled a few vibratos with them straight across on the string anchor. I think Olav got one of them when we did our first batch of lefties. Anyhow, I'm not sure if the Schaller's posts align with the ABM bridge but I will find out.
Dillon, as for the Fender spacing, Mosrite bridges were a little narrower than the bridges we're using - 2-1/16". Most Fenders are between 2-1/16" and 2-1/8" so the ABM or Rollermatic-style bridge would both work for your Jazzmaster project. Heck, we could even drill it out for Jazzmaster thimbles if you wanted to use a Jazzmaster or a Mustang bridge.
- Olav
The holes in my M3 vibrato are drilled straight across the string anchor. I have no way of comparing with a stagger-drilled vibrato, but mine works just brilliant.
va' sa' du? va' hete' du?
my guitars @ LGTf
my 2011TDPRI entry
my guitars @ LGTf
my 2011TDPRI entry
Hey Meng, that came out suu-weet!!
- raygun85
Olav wrote:The holes in my M3 vibrato are drilled straight across the string anchor. I have no way of comparing with a stagger-drilled vibrato, but mine works just brilliant.
Thats good to know for comparison's sake. I suppose a lot of players would probably prefer the staggered bores for vintage correctness. Personally, I prefer whatever stays in tune better. We'll have to do a side-by-side comparison. Maybe we can post the results on YouTube or something.
Matt,
Have you guys played around at all with string bores at different heights? Since bores that are farther from the axis of rotation would cover a greater distance per amount of arm movement, the higher up the bore relative to the axis, the greater the pitch range of the vibrato ought to be. I'm not sure there's enough room for there to be a significant difference, and it would also affect the string angle over the bridge, so maybe it's more pedantic than practical?
- olrocknroller
MWaldorf wrote:Matt,
It may be of interest for you to know that the tremolo on Nokie's HitchHiker has two rows of mounting holes or bores. For the dive-bombers, the upper row provides greater deflection, but in my experience, requires heavier strings to maintain a buzz-free contact with the bridge. I am using the lower range of bores with .009 - .046 strings (I have such tender fingers!
Users browsing this forum: No registered users and 590 guests
