So that makes two. Now spread a nice bit of glue on one of the pieces, let that sit for a couple minutes.
Mr. Bill wrote:Olav:
I've seen the insides of many vintage Danelectros and what you are building is far too nice!
I think that they just used whatever scrap wood they had for all of the interior bracing/filler pieces.
What color are you going to make it?
Danelectro's trademark was the masonite construction of the guitar bodies. The bodies were hollow, built around a wooden frame. The bridge was screwed into an internal wooden block that connected the top and back of the body. In earlier models, a piece of wood runs from the neck pocket to the bridge, while later models contain less internal structure.
Danelectro's well-known "lipstick" single-coil pickups are a big part of why these guitars sound so good. These are constructed around a single alnico bar magnet, wound to a relatively low (4.75k) resistance, and housed in an actual surplus lipstick tube.
Single-pickup long-scale Danelectro guitars originally came equipped with an ingenious three-way tone switch. Like many 50's single-pickup designs, this was intended for quick transitions between rhythm and lead tones, such as the Fender Esquire concept. In the lower switch position, the tone control (which was located where you would expect the volume control to be, closer to the bridge) functions normally. In the middle position, the tone control is bypassed entirely. In the top position, the tone control rolls off lows instead of highs, creating a sound similar to that of a bridge pickup.
On guitars with more than one pickup, Danelectro used "concentric" stacked knobs. In order to save money, the same generic three-way toggle switch found in the single-pickup guitars was used as a pickup selector switch. This is the real reason Danelectro guitars had their pickups wired in series, producing a big punchy sound with more output and midrange than individual pickup settings and eliminating hum. Parallel wiring (as used by virtually all other manufacturers) would have required a slightly more expensive switch!
Users browsing this forum: No registered users and 405 guests
