Vibramute trem dimensions
Re: Vibramute trem dimensions
Postby MWaldorf » Mon Feb 15, 2010 10:56 pm
Oigun,
Wow, that's fantastic! You must be a very patient fellow! Yes, the trem is balanced between the tension of the spring and the tension of the strings.
oigun
Postby oigun » Tue Feb 16, 2010 9:25 am
Thanks Mel,Gabber I love your music. The word mesjokke like many words is completely adapted in the dutch language especially nearby Amsterdam there are plenty of jiddish words that are used in common language. The combination traditional jiddish music and surf is genious :mrgreen: :mrgreen: :mrgreen:
The staggered string holes in the vibramute trem are they there for a purpous? Or is it ok to drill them all in one line??
Postby Veenture » Tue Feb 16, 2010 10:54 am
oigun wrote:The staggered string holes in the vibramute trem are they there for a purpous? Or is it ok to drill them all in one line??
see: viewtopic.php?f=20&t=1849&hilit=staggered
and viewtopic.php?f=20&t=842
"de mazzel" oigun ;)
Olav
Postby Olav » Wed Feb 17, 2010 4:02 am
Thanks, ook namens Oigun.
The vibrato Oigun is building is supposed to go on my guitar.
I (or We really) still haven't decided if we're going to install a mute and a compensated bridge or a rollerbridge.
We (or at least I) are looking to make this a pretty versatile guitar without taking away from looks.
Opinions/tips are most welcome.
va' sa' du? va' hete' du?
my guitars @ LGTf
my 2011TDPRI entry
oigun
Postby oigun » Wed Feb 17, 2010 8:50 am
[QUOTE OLAV]make this a pretty versatile guitar [/QUOTE]
Nope. Sorry olav its surf only.... :mrgreen: .
Butch
Postby Butch » Mon May 14, 2012 10:51 am
dubtrub wrote:Well, I see no one has responded to your question. so I'll give it a try. I will try to describe the area where I take the measurements and hopefully you will be able to follow what I'm trying to describe. Measurements will be in inches.
Overall length, 4 1/16"
Length from the bridge side of base plate to the curved recess where the Vibramute writing is located, 3 13/16"
Width at the widest point, that being where the spring area protrudes farther out from the rest of the plate, 3 7/16"
Width at bridge end of base, 3 3/16"
Width at opposite end where it say's Vibramute, 3 3/16"
Height where the bearings for the rocker attaches, 15/64"
Center of rocker bearing hole from end of base, 1 1/8"
Center of recess for the spring measuring from the base end 1 15/16"
Thickness of base plate is 3/16"
Once you get that done, let me know and I will give you the measurements for the rocker and arm assembly if you need it.
WHAT ARE THE MEASUREMENTS FOR THE ROCKER ARM AND ASSEMBLY, LIKE THE HEIGHT OF THE PEDESTALS ?
Postby dubtrub » Mon May 14, 2012 7:11 pm
Butch wrote:WHAT ARE THE MEASUREMENTS FOR THE ROCKER ARM AND ASSEMBLY, LIKE THE HEIGHT OF THE PEDESTALS ?
Check out this topic. viewtopic.php?f=20&t=4772
Butch
Postby Butch » Mon May 14, 2012 9:02 pm
Thanks Danny ! This will help me 100%. And believe me I need all the help I can get.......Thank You !
Postby oipunkguy » Mon May 14, 2012 10:05 pm
hey Eugen,
can you show us the equipment you're using to make this? i'd like to try it sometime. besides, you know me one. ;)
raygun85
Postby raygun85 » Wed May 16, 2012 10:01 am
oipunkguy wrote:besides, you know me one. ;)
Doesn't everybody? :lol:
