Danny,
I can see that a lock washer would be a good idea. I played a 3 hour gig last night and the arm held it's firmness even with plenty of twisting it back and forth, so I'm guessing that the plastic washer and liquid lockwasher is going to do the trick as well.
Thanks for sharing the secret, me and my Mosrite thank you!
loose arm?
Re: loose arm?
Re: loose arm?
MWaldorf wrote:Danny,
OK, so, one more time for the record......the sequence of pieces are:
Base,_______,_______,_______,________,Arm.....????
Re: loose arm?
In my case from top to bottom:
arm handle (stock)
leather washer (stock)
plastic washer
arm mount (stock) - does this piece has a proper name?
washer (stock)
bolt (stock) w/drop of liquid lockwasher
I removed a paper gasket that was between the leather and the mount.
arm handle (stock)
plastic washer
washer (stock)
brunob
Re: loose arm?
1st gig with the Ranger,after half an hour the arm start loosing,I had no wrench with me,a nightmare,we-los (the)Wet-Tones ,play usually 30-34 tunes ,so after 15 tunes ,the arm(I fixed with a rubber washer very tight) loose!
it's different from the original or a Excellent ,a bad design,very easy to loose,you can tighteen it as you want,but after the washer is compressed it start loose again.
I saw the picture in this section,but I think it doesn't work on the Ranger bridge style design.
Any suggestion?
Bruno
Any suggestion?
Re: loose arm?
Bruno,
Have you tried liquid lockwasher? Sometimes it's also called liquid threadlock.
brunob
Re: loose arm?
I have to get it!I really don't like tremolo arm floating down,but the screw seems to get loose as you moive the arm,so I will try it!
Thanx
what about your Meltones?
ciao Bruno
Thanx
ciao Bruno
Re: loose arm?
brunob wrote:what about your Meltones?
The Meltones aren't really a gigging entity anymore, but we released an album a few years ago called "Surf! Spy! Space!" which you can find on CDBaby:
http://cdbaby.com/cd/meltones2
A compilation of our first two CDs is also available, called "Surf Sensation":
Users browsing this forum: No registered users and 499 guests
