loose arm?
Re: loose arm?
Postby MWaldorf » Fri Jun 20, 2008 11:35 am
Danny,
I can see that a lock washer would be a good idea. I played a 3 hour gig last night and the arm held it's firmness even with plenty of twisting it back and forth, so I'm guessing that the plastic washer and liquid lockwasher is going to do the trick as well.
Thanks for sharing the secret, me and my Mosrite thank you!
Re: loose arm?
Postby Dennisthe Menace » Fri Jun 20, 2008 12:03 pm
MWaldorf wrote:Danny,
OK, so, one more time for the record......the sequence of pieces are:
Base,_______,_______,_______,________,Arm.....????
Re: loose arm?
Postby MWaldorf » Fri Jun 20, 2008 12:37 pm
In my case from top to bottom:
arm handle (stock)
leather washer (stock)
plastic washer
arm mount (stock) - does this piece has a proper name?
washer (stock)
bolt (stock) w/drop of liquid lockwasher
I removed a paper gasket that was between the leather and the mount.
Users browsing this forum: No registered users and 101 guests
